How to convert yuv to rgb8/rgb8a/rgb32/rgb32f to use Imagenet/detectnet/segnet in jetson-inference
##YUV conversion to rgb for jetson inference
The data from the input stream is of yuv422 format. I am trying detect some objects using already implimented detectnet algorithm on jetson-inference on my jetson AGX. But it seems the input streams and input to the detectnet network should be of RGB/RGBA formats are the only ones that should be used with the uchar3 / uchar4 / float3 / float4 vector types. Is there an possible way to convert yuv422 to those format so that I detect with jetson inferense.
Query: I saw some API like CUDA NPP. Is it possible to use those in my use case? if so, how? Any help would be appreciated. Thanks in Advance
The below link might be useful for you
https://docs.nvidia.com/deeplearning/tensorrt/best-practices/index.html#thread-safety
https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#stream-priorities
https://docs.nvidia.com/cuda/cuda-runtime-api/group__CUDART__STREAM.html
For multi threading/streaming, will suggest you to use Deepstream or TRITON
For more details, we recommend you to raise the query to the Deepstream or TRITON forum.
