There are exceptions to what follows, but for the most part the following should work…
When booting the “/boot/extlinux/extlinux.conf
” will name where the Image
file is (by default “/boot/Image
”) via the “LINUX
” key/value pair. I generally suggest that people do not overwrite the original Image, but instead add a duplicate entry, use serial console to pick that entry while testing, and after that make the new entry the default. Example extlinux.conf:
TIMEOUT 30
DEFAULT primary
MENU TITLE p2771-0000 eMMC boot options
TIMEOUT 30
DEFAULT test
LABEL primary
MENU LABEL original kernel
LINUX /boot/Image
APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
LABEL test
MENU LABEL usb test
LINUX /boot/Image-4.9.140-tegra-test
(and then add the Image
file as a file copy to “/boot/Image-4.9.140-test-tegra
”; I have conveniently named this after what I think my new “uname -r
” will be)
Here is the trick: Depending on flash parameters, the extlinux.conf
might be the one in eMMC, or it might be the one on the USB drive. I’ve purposely renamed the “MENU LABEL
” to reflect this, and if I don’t see it on serial console, then it implies I edited the wrong extlinux.conf
. If you’ve flashed and set the USB drive correctly, then you would only need to edit on the USB drive.
There is also an additional “FDT
” parameter. For awhile this was not used on some of the Jetsons, but for the most part it should work on anything recent. This key/value pair is for naming the kernel device tree (note that there is other device tree content in a partition which might be used by earlier boot stages). For the most part naming a device tree binary in “/boot
” should work (exceptions might exist if you are set up for signed content in partitions instead of direct device tree file load).
An example device tree, if it is file name “tegra186-quill-p3310-1000-c03-00-base.dtb
”, would be:
LABEL test
MENU LABEL usb test
FDT /boot/tegra186-quill-p3310-1000-c03-00-custom.dtb
In that example I named the file “tegra186-quill-p3310-1000-c03-00-custom.dtb
”, with “custom” since it is not the original. You would then copy this to “/boot/tegra186-quill-p3310-1000-c03-00-custom.dtb
” of the correct partition (USB or eMMC, depending on flash parameters).
Note that if you use a new Image
which changes the output of “uname -r
” that you must also add all modules in built for that “uname -r
”. Modules are searched for in “/lib/modules/$(uname -r)/kernel/
