How to copy or move metadata to another gstBuffer
• Hardware Platform (Jetson / GPU) [Jetson]
• DeepStream Version [6.0]
• JetPack Version (valid for Jetson only) [4.6.1]
• TensorRT Version [10.2]
• Issue Type( questions, new requirements, bugs) [questions]
Hi, I made two pipelines which is for decoding and display in one process.
decoding pipeline is
appsrc ! h264parse ! nvv4l2decoder ! nvstreammux ! appsink
display pipeline is
appsrc ! queue ! nvvideoconvert ! nvosd ! nvegltransform ! nveglglessink
I refered to this commend https://forums.developer.nvidia.com/t/nveglrender-does-not-display/309338/7?u=mjnhb20011 to send buffer from decoding pipeline to display pipeline and it worked well.
I wanted to add metadata in decoding pipeline and use it on display pipeline. so I added nvstreammux element in decoding pipeline.
In https://forums.developer.nvidia.com/t/nveglrender-does-not-display/309338/7?u=mjnhb20011 commend, there was no copy metadata to new gstBuffer.
So, I just get metadata using gst_buffer_get_nvds_batch_meta and gst_buffer_add_nvds_meta function to add metadata for new gstbuffer.
but this code didn’t work and crashed my program.
Is there any proper way to send of copy metadata from pipeline to another pipeline?
Solved by using gst_buffer_copy_into function.
