I copied the files from /optee/install/t234 from host to target which is an jetson_agx_orin_devkit , but the tee-supplicant file is not copied, it says text file busy when i am copying it to the /usr/sbin/* . I want to know what should be the exact command for copying these files from /optee/install/t234 to the target, which destination in the target. Kindly help me.
Hi JerryChang,
I have read through the comments. I have generated the tos, flashed it successfully, sudo xtest also passes, but tee-supplicant -d is not passing. I think because I am not following step 3 of the veryfying the image whi
ch is
Copy all the files under ./optee/install/t to the target.
I have build a kernel as specified in the documentation - kernel customization. Then build optee. I have attached the output of the $ cat /etc/nv_tegra_release .
it looks you’re using JetPack 6.2.1/r36.4.4.
the logs you shared before seems truncated. please also share the the complete UART logs of sudo tee-supplicant for reference.
Hi JerryChang,
I have build the kernel from the BSP sources and drivers, and generating the whole os image as instructed in the developer guide for l4T36.4.4 . After flashing the whole os to the target I am unable to connect to the network or wifi or lan in the target, hence I used a pendrive to copy the files in the /optee/install/t234 making it a tar file, then extracted in the target and tried to copy, So now in the target I have files in ’ /home/agxorin/Desktop/t234 ’ location and I copied with the following commands.
’ sudo rsync -a bin/ /bin/
sudo rsync -a lib/ /lib/
sudo rsync -a usr/ /usr/ ’
$ sudo xtest
35134 subtests of which 0 failed
137 test cases of which 0 failed
0 test cases were skipped
TEE test application done!
you may also gather the logs with.. journalctl -u nv-tee-supplicant.service
this is not expected, did you flashing with native JetPack 6.2.1/r36.4.4 public release version?
may I know your complete steps for flashing the whole os to the target, and it shows unable to connect to the network. we would like to reproduce this locally.
Hi JerryChang,
I have build the kernel, then compiled successfully, after that followed the README.txt file in the atf and optee folder and followed all the steps (generated tos succesfully), then flashed the os by following code :
sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
to the target board. If you need some further details like flashing logs, let me know.
Now my main concerns are as follows:
How to copy the optee/install/t234 files successfully to the target and to run the tee-supplicant. and
If the commandsudo tee-supplicant gives error, then how sudo xtestpasses before copying the files to the target?
If sudo xtest passes, does this suffice that tos is working properly?
After copying the files optee\install\t234to the target, why after running sudo xtest it says segment fault as error (serials logs are attached above named as output_after_copying.txt).
I encountered the same error when running sudo xtest after installing the files from <optee_src>/optee/install/t234 that I had rebuilt.
The error message indicates that it cannot open the ee90d523-90ad-46a0-859d-8eea0b150086.ta TA file. I’ve verified that there is indeed no such file in /lib/optee_armtz ."
* regression_1024 Test PTA_SYSTEM_GET_TPM_EVENT_LOG Service
覟/LD: init_elf:493 sys_open_ta_bin(ee90d523-90ad-46a0-859d-8eea0b150086)
E/TC:?? 00 ldelf_init_with_ldelf:152 ldelf failed with res: 0xffff0008
嫪 regression_1024.1 TPM test service invocation
Segmentation fault
please ignore the regression_1024 test failure.
this is known issue, the xtest crashes when trying to run regression_1024 test case.
that’s due to it always assume the PCR index 0 with a default value, this test would be always fail as we enabled measured boot. (i.e. the PCR 0 is not a fixed value).
for instance, optee_test/ta/tpm_log_test/ta_entry.c at master · OP-TEE/optee_test · GitHub
you’ll only see such failure with the generated TOS image (i.e. re-build the TOS image and all optee userspace programs and libraries following the atf_and_optee_README.txt)
or.. you may try to disable CFG_CORE_TPM_EVENT_LOG to re-built optee to avoid regression_1024 test-case.
