• Hardware Platform (Jetson / GPU): Jetson AGX Xavier
• DeepStream Version: 5.0
• JetPack Version (valid for Jetson only): 4.4
• TensorRT Version: 7.1.3
• Issue Type( questions, new requirements, bugs): question
The example apps show the total counts of each class for each frame but not the accumulated total counts (exclude duplicated appearances). I want to keep track how many unique objects of a class appear in total so I think I need to use the tracker id to discard duplicated occurrences. In other words, when an object of class A appears in multiple frames, only its first occurrence contribute to the total count of class A.
I read from the nvdsmeta.h file that UNTRACKED_OBJECT_ID
indicates that the object has not been tracked, I wonder if I can use it to detect first occurrence of an object? Say:
if(object_id == UNTRACKED_OBJECT_ID) // first occurrence
update count
else // subsequent occurrence, object_id is set to a value other than UNTRACKED_OBJECT_ID
pass
