How to create a backup image in jetpack 5.1.4 after secure boot
I’m trying to create a backup from JetPack 5.1.4 using the following command:
sudo ./flash.sh -r -k APP -G backup.img -u vio_rsa_priv.pem -v sbk.key jetson-xavier-nx-devkit-emmc mmcblk0p1
However, it seems to hang at same the picture. I want to know if there’s anything wrong with the command I’m using to create the backup. Additional information: when I use the following method, everything works fine without any issues:
sudo ./tools/backup_restore/l4t_backup_restore.sh -u vio_rsa_priv.pem -v sbk.key -b jetson-xavier-nx-devkit-emmc
So, what is the difference between these two methods? Which one should I use?
hello user34150,
it’s due to partition commands (-k) is not works after secure boot enabled.
So with the Secure Boot method, I can only use:
to create a backup and reflash, right? @JerryChang
yes, please running with backup-restore script for your use-case.
