Hi all,
I’m trying to model a plant leaf with four connected rigid parts in Isaac Sim using USD/PhysX Articulation.
The structure is like a “ring” (closed-loop):
- Leaf1 connects to Leaf2 by a hinge joint
- Leaf2 connects to Leaf3 by a hinge joint
- Leaf3 connects to Leaf4 by a hinge joint
- Leaf4 should connect back to Leaf1 with a rigid “weld” (distance constraint, or fixed joint)
My current setup:
- I use Articulation (chain of hinge joints) for all leaves
- I tried to add a
DistanceJoint(or FixedJoint) between Leaf4 and Leaf1 to form a closed loop
Issue:
- PhysX reports:
Articulation cannot contain a distance joint! (Please exclude it from articulation) - If I use only Articulation joints, I cannot create a “ring” because articulation must be tree-shaped
Questions:
- What is the recommended way to “weld” (rigidly connect) two non-parent/child links (e.g., Leaf1 and Leaf4) in the same Articulation, forming a closed-loop, in Isaac Sim/PhysX?
- Is there any official workaround to create a “closed kinematic loop” or “ring” structure in articulation?
- If not possible in Articulation, is there any other PhysX-supported mechanism in Isaac Sim to achieve this kind of loop with strict distance or rigid constraint?
Notes:
- I do not want the “soft” constraint; it should be as rigid as possible, like a true weld.
- Using PhysxSchema is not an option on my current setup.
Any advice, sample code, or official documentation reference would be appreciated!
