• Hardware Platform (Jetson / GPU): Jetson Orin Nano 8GB
• DeepStream Version: 6.3
• JetPack Version (valid for Jetson only): 5.1.2
• Issue Type( questions, new requirements, bugs): Question
I am trying to write a custom Deepstream element for GStreamer which utilizes CUDA resources and NVDS object metadata to generate a depth map from a batched frame input. This requires me to do an out of place transform rather than an in place transform, since CUDA-accelerated OpenCV operations don’t necessarily overwrite all data in their buffers which can lead to erroneous disparity calculations. All of the provided custom deepstream plugin examples perform in place transformations except for the dewarper, which does not seem to utilize opencv in any meaningful way. While I have figured out how to get my data out of the input buffer in my transfrom
function, I cannot figure out how to allocate and use the output buffer. When I try to map the output buffer using NvBufSurfaceMap
it throws an error that does not provide any helpful information as to why the buffer mapping failed. Are there any examples of doing OpenCV processing with Deepstream in a custom plugin which utilize the output buffer in their transform function? Furthermore, are there any examples of doing this with CUDA accelerated OpenCV functions? I have done a ton of research and cannot seem to find any examples or documentation detailing how this should be accomplished.
