How to create a customized INvDsInPlaceDataHandler component?
**• Hardware Platform (Jetson / GPU) **GPU
• DeepStream Version6.2
**• JetPack Version (valid for Jetson only)**6.2
• TensorRT Version
**• NVIDIA GPU Driver Version (valid for GPU only)**525
**• Issue Type( questions, new requirements, bugs)**questions
I want to implement some functionality, like nvidia::deepstream::NvDsSampleProbeMessageMetaCreation using my own models and classes.
Do you have the source file for this component?
Do I have to build my own extension to achieve this kind of customized functionality? Can this be done by combining other components in graph composer?
Screenshot from 2023-05-30 02-16-42
If I uncheck the generate-dummy-data box, does this mean the following “vehicle-type-unique-id car-make-unique-id car-color-unique-id” won’t affect the message?
And, does this mean I can just use this sample extension to generate payload with my own model specified by config file in the infer component?
The source code is not published.
If you want to generate different types of message meta, you need to customize your own extension.
No.
No. "check/uncheck ‘generate-dummy-data’ " only impacts the bbox coordinates and “person” objects information in the message.
Thanks,
If I want to use container build tool on x86 dev platform for jetson deploying, do I need run both
bazel build … and build … --config=jetson on the x86 dev platform?
BTW how can I unregister a extension or update the same name extension to a new version?
Container Builder is the tool which can be used to generate docker for the graphs. Please refer to the usage Container Builder — DeepStream 6.2 Release documentation
You can use the following commands to clean the registered extensions
registry repo clean
registry cache -c
Please refer to the registry usage Registry — DeepStream 6.2 Release documentation
Different extension versions can co-exist.
