Hello, I’m looking to create an OTA payload package that will update my existing Jetpack 4.4 system to have more SDK components enabled. I am trying to follow the directions found here: Updating Jetson Linux with Image based OTA update
I tried to find the corresponding OTA tools package for 4.4 but found that the OTA tools only exist for jetpack 4.6.1. someone looking for ota tools location
Could I possible use a newer ota tools package to create an image based OTA payload package?
I did try using the ota tools package for jetpack 4.6.1 but ran into some problems when I tried to execute step 12.
SUCCESS: get dtbfile name “”
Unpacking initrd …
23652 blocks
grep: /home/test/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra//tools/ota_tools/version_upgrade/recovery_copy_binlist.txt: No such file or directory
/tmp/R32_3_4_recovery/initrd_tmp/lib /tmp/R32_3_4_recovery/initrd_tmp ~/nvidia/nvidia_sdk/JetPack_4.4_Linux_JETSON_AGX_XAVIER/Linux_for_Tegra
sed: can’t read /tmp/R32_3_4_recovery/initrd_tmp/sbin/dhclient-script: No such file or directory
Hello Wayne, thank you for your very quick and concise answer! I only saw that OTA was available for 4.4 so I thought the image based OTA would be available as well. Thank you for the clarification.
So, If I have an board flashed with Jetpack 4.6 (or whatever is the latest jetpack), I could imaged based OTA payload package to upgrade whatever machines I have Jetpack 4.4 on. Would I still need to perform step 12?
Also, I see that someone asked for help in creating a clone based payload package. ota customized image clone they were advised to use this command line: sudo ./l4t_generate_ota_package.sh -f user_rootfs.img -o user_rootfs_updater.sh <board_name> <bsp_version>
the user_rootfs_updater.sh is based upon nv_ota_rootfs_updater.sh
I have read the documentation and am not sure how to customize nv_ota_rootfs_updater.sh. the documentation seems to be only 1 paragraph:
The default rootfs updater’s usage is:
nv_ota_rootfs_updater.sh [-p ] [-d ]
Where:
• is the device node path of the rootfs partition, for example, /dev/mmcblk0p1.
• is the path of the OTA work directory, for example, /ota_work.
• is the path of the rootfs image, for example, /ota_work/system.img.
If you create a customized rootfs image, you must specify a rootfs updater that can process that image. The rootfs updater you specify must expect the same arguments and options as nv_ota_rootfs_updater.sh. Your update may use these arguments and options or not, depending on your specific needs.
Do you know where I could find more documentation on how to customize nv_ota_rootfs_updater.sh? Do I really need to customize it? Or can I just use it as is?
