How to create a sequent kernel in CUF or CUDA FORTRAN
Hi Experts,
To remove the unnecessary data movements between host and device, sometimes I may need to define a sequent kernel by using CUF or CUDA FORTRAN. I know how to do this in OpenACC ( ACC SEQ), but have no idea about how to do this through CUF or CUDA FORTRAN. Can anyone give me some idea about this?
Thank you so much!
Use a schedule of 1 block with 1 vector.
call foo <<<1,1>> (args)
!$cuf kernel do <<<1,1>>>
Thank you Mat.
Look at this code:
program test
!@cuf use cudafor
            integer :: II
            integer :: istat
            !$CUF kernel do <<<1,1>>>
            II = 1
            istat = cudaDeviceSynchronize()
            print *, II
    end program
I got compiling errors:
nvfortran -cuda ./test.F90
NVFORTRAN-S-0104-Illegal control structure - unterminated CUDA KERNEL directive (./test.F90: 7)
0 inform, 0 warnings, 1 severes, 0 fatal for test
If I remove the “do” in the CUF line, I got:
NVFORTRAN-S-0034-Syntax error at or near ‘<<<’ (./test.F90: 7)
Maybe I have made a silly mistake?
Sorry, for CUF kernels, there needs to be a loop so in this case, you’ll need to do something like:
        do I=1,1
          II = 1
        end do
Note that OpenACC can be intermixed so it might be easiest to mix in a serial region
!$acc serial
II=1
!$acc end serial
Thank you Mat, this works!
