Hi there,
I am developing a build system for the Orin that installs some customizations on top of the rootfs. In addition to these customization, I am building machine learning Docker containers that I am loading onto the rootfs.
So the rootfs basically stays the same across builds, but a single file (tarball of the Docker containers to load) will change from build-to-build.
In order to avoid the overhead of having to re-flash the entire rootfs, is it possible to create another partition solely for the Docker containers, that on boot gets mounted as a path on the file system?
For example, here is the partition layout that would be ideal on an external NVMe:
Partition: APP: contains the rootfs
Partition: DOCKER: contains the Docker tarball for all of the containers I want to load on first boot
Is it possible to setup an Orin this way, and then only flash the DOCKER partition?
Thanks, any guidance is appreciated.
Gabe
