How to create IB partitions without enabling IPOIB
HI,
I’ve been trying out setting up of partitions in our IB fabric. I’m using a SX6036 with the onboard SM enabled. I have thre nodes which are connected to this switch. I’ve done the following changes to the partition config.
Default Partition → FULL Membership for SELF
LIMITED membership for ALL
Test Partition 0x0010 → Full Membership for GUID’s of two of the nodes.
When I try to run ib_send_lat or any of the test programs, I keep getting the following error on the sending side
Completion with error at client
Failed status 12: wr_id 0 syndrom 0x81
scnt=1, ccnt=1
In the SM logs, I keep getting a message
log_trap_info: Received Generic Notice type:2 num:257 (Bad P_Key) Producer:1 (Channel Adapter) from …
What am I doing wrong ?I must mention, when I give FULL Membership to ALL in the Default partition, all nodes can talk to each other, but that’s not what I want to achieve.
Any tips are appreciated.
/D
In order to let to the nodes communicate over configured partition child interface should be created for IPoIB interface, or application should specify the P_Key.
Did you try to use ib_send_lat (or other) tools with --pkey_index argument?
