In order to transfer our product from development to production we need to create a massflash blob.
Currently we are flashing customized rootfs which was backup from customized Xavier module by using the following command sudo ./flash.sh -r -k APP mmcblk0p1., while the image itself is system.img file.
How can I generate a massflash blob which will consists my customized rootfs?
hello yehonatans68sw4,
you may enable -G <file_name>
options to read the boot partition and saves the image to the specified file. after that, keep the backup system.img at your host machine for running nvmassflashgen.sh
, it’ll create the Massflash blob with your customize rootfs.
please see-also developer guide, To clone a Jetson device and flash for sample commands to backup filesystem partition,
thanks
Thank’s for the answer I would like to know what is the location should be for my rootfs that it will be used by nvmassflashgen.sh
it’ll take the images under bootloader/
of your JetPack install path.
for example, ~/nvidia/nvidia_sdk/JetPack_<version>_Linux_<platform>/Linux_for_Tegra/bootloader/
note,
once you’ve backup your rootfs, you must include -r
options to the nvmassflashgen
commands, it’ll reuse the existing system.img
for creating mfi package.
here’s an example to create mass Flashing tarball by reuse system.img
for a non-fuse Xavier-NX platform,
$ sudo BOARDID=3668 BOARDSKU=0001 FAB=100 BOARDREV=H.0 FUSELEVEL=fuselevel_none ./nvmassflashgen.sh -x 0x19 -r jetson-xavier-nx-devkit-emmc mmcblk0p1
you’ll see below messages…
Reusing existing system.img...
done.
when the mass flashing tarball mfi_jetson-xavier-nx-devkit-emmc.tbz2 is ready
that’s mfi_jetson-xavier-nx-devkit-emmc/system.img
, be your customize rootfs.
thanks
