How to create metadatacontainer without egl display?
We want use BayerAverageMap extension in our project.
So we have to create a metadatacontainer by EGLStream::MetadataContainer::create method, Just like jetson mmapi samples.
But the first parameter of create method is EGLDisplay, In our scenario, there is no display available. For example, in a gstreamer source plugin(like nvarguscamerasrc) , How can we create a metadatacontainer?
Thank you!!
There is reference code in 10_camera_recording. Please try
    /* Get default EGL display */
    eglDisplay = eglGetDisplay(EGL_DEFAULT_DISPLAY);
Hi, Dane
Thanks for your reply!
The eglGetDisplay(EGL_DEFAULT_DISPLAY) works on X11.
But our app using nvoverlaysink without X.
Is there a way get display without X?
Beside,I can’t understood why metadatacontainer require a display parameter.
The all metadata provided by stream. Maybe the host does not have a display,
Please refer to
Could you check if you have nvdisplay enabled? On default r32.4.3, we can run 10_camera_recording after disabling display manager:
$ sudo systemctl stop gdm
$ sudo loginctl terminate-seat seat0
So it should work without X.
