• Hardware Platform (Jetson / GPU): Jestson Nano
• DeepStream Version: 5.1
• JetPack Version: 4.5
• TensorRT Version: 7.1.3.0
• TLT Version: 3.0
Hello there,
We are trying to train the custom ALPR model and we are facing this error:
Cmd:
tlt detectnet_v2 dataset_convert -d ./SPECS_tfrecord.txt -o ./lpd_tfrecord/lpd
Error:
“No file found at: {}. Did you run docker login?”.format(config_path)
AssertionError: Config path must be a valid unix path. No file found at: /home/amnt_ssip/.docker/config.json. Did you run docker login?
Please help us to solve this issue.
Thanks and Regards,
Naresh Mungpara
