I was able to create and flash the logo blob. Upon boot no logo. Everything else was fine. I think I need to understand the format of the bmp file. Can some use mediainfo and show me there format and what tools they used to create their original logo bmp before the reduce colors steps. Better yet can someone at Nvidia send me one of the original bmp logo files. Thanks.
I tired 2 method to create the bmp file and here is the info using file command.
locbit-rc-16-1920x1080.bmp: PC bitmap, Windows 98/2000 and newer format, 1920 x 1080 x 4
locbit-rc-1920x1080.bmp: PC bitmap, Windows 95/NT4 and newer format, 1920 x 1080 x 4
does that look correct?
here is info using mediainfo
General
Count : 330
Count of stream of this kind : 1
Kind of stream : General
Stream identifier : 0
Count of image streams : 1
Image_Format_List : RGB
Image_Format_WithHint_List : RGB
Codecs Image : RGB
Complete name : locbit-rc-1920x1080.bmp
File name : locbit-rc-1920x1080.bmp
File extension : bmp
Format : Bitmap
Format : Bitmap
Format/Extensions usually used : bmp bms
Commercial name : Bitmap
Internet media type : image/bmp
Codec : Bitmap
Codec : Bitmap
Codec/Extensions usually used : bmp bms
File size : 1036986
File size : 1 013 KiB
File size : 1 012.7 KiB
File last modification date : UTC 2020-11-25 01:51:40
File last modification date (local) : 2020-11-24 20:51:40
Count : 122
Kind of stream : Image
Format : RGB
Commercial name : RGB
Codec : RGB
Codec : RGB
Width : 1920
Width : 1 920 pixels
Height : 1080
Height : 1 080 pixels
Color space : RGB
Resolution : 8
Resolution : 8 bits
Bit depth : 8
Bit depth : 8 bits
And
General
Count : 330
Codecs Image : RGB
Complete name : locbit-rc-16-1920x1080.bmp
File name : locbit-rc-16-1920x1080.bmp
Format : Bitmap
Format : Bitmap
Codec : Bitmap
Codec : Bitmap
File size : 1037002
File last modification date : UTC 2020-11-24 16:40:56
File last modification date (local) : 2020-11-24 11:40:56
Count : 122
Format : RGB
Codec : RGB
Codec : RGB
Width : 1920
Height : 1080
Color space : RGB
Resolution : 8
Resolution : 8 bits
Bit depth : 8
Bit depth : 8 bits
