How to Crop RTSP Stream Input in DeepStream for Model Inference?
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 7.0
• TensorRT Version
• NVIDIA GPU Driver Version (valid for GPU only) 535.171.04
• Issue Type( questions, new requirements, bugs) questions
I am trying to use DeepStream to detect people. The problem is that the model I am using crops the image into windows for inference. Below is the Python code that crops the image into windows.
windows = []
for i in range(num_rows):
    for j in range(num_cols):
        x_start, y_start = i * stride_height, j * stride_width
        x_end, y_end = x_start + window_height, y_start + window_width
        if x_end > image_height:
            x_start, x_end = image_height - window_height, image_height
        if y_end > image_width:
            y_start, y_end = image_width - window_width, image_width
        window = image[:, :, x_start:x_end, y_start:y_end]
        windows.append(window)
windows = torch.cat(windows, dim=0).to(image.device)  # batched windows, shape: (num_windows, c, h, w)
model.eval()
with torch.no_grad():
    preds = model(windows)
preds = preds.cpu().detach().numpy()
I successfully converted this model to ONNX format, but I don’t know how to crop the input RTSP stream in DeepStream.
Can I crop the RTSP stream input in DeepStream to use this model? If so, what method should I use?
I am using DeepStream through the Python binding method.
I hope this helps!
  1. which deepstream sample are you testing or referring to?
  2. do you mean you only want the part of whole frame to do inference? there are two solutions.
    solution1: you can use nvdspreprocess’s ROI. please refer to the sample deepstream_preprocess_test.py.
    solution2: you can use nvvideoconvert to crop the designated part. there is a sample to crop the 0,0,300,300 area.
gst-launch-1.0 filesrc location= /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg ! jpegdec ! 'video/x-raw,format=I420' ! nvvideoconvert  src-crop=“0:0:300:300” ! jpegenc ! filesink location=7.jpeg
Thank you for your response.
Previously, I was using P2PNet and modified the RTSP-in-RTSP-out example. I am currently modifying the DeepStream Python code to fit a better model I found.
Below is the pipeline structure of the Python code I am currently using.
Gst.init(None)
    mem_type = int(pyds.NVBUF_MEM_CUDA_UNIFIED)
    loop = GLib.MainLoop()
    pipeline = Gst.Pipeline()
    if not pipeline:
        sys.stderr.write('ERROR: Failed to create pipeline\n')
        sys.exit(1)
    streammux = Gst.ElementFactory.make('nvstreammux', 'nvstreammux')
    if not streammux:
        sys.stderr.write('ERROR: Failed to create nvstreammux\n')
        sys.exit(1)
    streammux.set_property("nvbuf-memory-type", mem_type)
    pipeline.add(streammux)
    tiler = Gst.ElementFactory.make('nvmultistreamtiler', 'nvtiler')
    if not tiler:
        sys.stderr.write('ERROR: Failed to create nvmultistreamtiler\n')
        sys.exit(1)
    tiler.set_property('rows', ROWS)
    tiler.set_property('columns', COLUMNS)
    tiler.set_property('width', STREAMMUX_WIDTH / ROWS)
    tiler.set_property('height', STREAMMUX_HEIGHT / COLUMNS)
    pipeline.add(tiler)
    pgie = Gst.ElementFactory.make('nvinfer', 'pgie')
    if not pgie:
        sys.stderr.write('ERROR: Failed to create nvinfer\n')
        sys.exit(1)
    converter = Gst.ElementFactory.make('nvvideoconvert', 'nvvideoconvert')
    if not converter:
        sys.stderr.write('ERROR: Failed to create nvvideoconvert\n')
        sys.exit(1)
    converter.set_property("nvbuf-memory-type", mem_type)
    capsfilter = Gst.ElementFactory.make('capsfilter', 'capsfilter')
    if not capsfilter:
        sys.stderr.write('ERROR: Failed to create capsfilter\n')
        sys.exit(1)
    capsfilter.set_property('caps', Gst.Caps.from_string('video/x-raw(memory:NVMM), format=RGBA'))
    pipeline.add(capsfilter)
    osd = Gst.ElementFactory.make('nvdsosd', 'nvdsosd')
    if not osd:
        sys.stderr.write('ERROR: Failed to create nvdsosd\n')
        sys.exit(1)
    nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
    caps = Gst.ElementFactory.make("capsfilter", "filter")
    caps.set_property(
        "caps", Gst.Caps.from_string(f"video/x-raw(memory:NVMM), format=I420, width=(int)1920, height=(int)1080")
    # Make the encoder
    encoder = Gst.ElementFactory.make("nvv4l2h264enc", "encoder")
    if not encoder:
        sys.stderr.write(" Unable to create encoder")
    encoder.set_property("bitrate", bitrate)
    # encoder.set_property("bitrate", 8000000)
    encoder.set_property("iframeinterval", 60)
    encoder.set_property("profile", 2)
    # Make the payload-encode video into RTP packets
    rtppay = Gst.ElementFactory.make("rtph264pay", "rtppay")
    # rtppay.set_property("mtu", 1400)
    print("Creating H264 rtppay")
    # Make the UDP sink
    udpsink_port_num = 25400
    sink = Gst.ElementFactory.make("udpsink", "udpsink")
    if not sink:
        sys.stderr.write(" Unable to create udpsink")
    sink.set_property("host", "127.0.0.1")
    sink.set_property("port", udpsink_port_num)
    sink.set_property("async", False)
    sink.set_property("sync", True)
    sink.set_property("buffer-size", buf_size)
    streammux.set_property('batch-size', STREAMMUX_BATCH_SIZE)
    streammux.set_property('batched-push-timeout', 25000)
    streammux.set_property('width', STREAMMUX_WIDTH)
    streammux.set_property('height', STREAMMUX_HEIGHT)
    streammux.set_property('enable-padding', 0)
    streammux.set_property('live-source', True)
    streammux.set_property('attach-sys-ts', True)
    pgie.set_property('config-file-path', CONFIG_INFER)
    osd.set_property('process-mode', int(pyds.MODE_GPU))
    osd.set_property('display-bbox', 1)
    osd.set_property('display-text', 0)
    pipeline.add(pgie)
    pipeline.add(converter)
    pipeline.add(osd)
    pipeline.add(nvvidconv_postosd)
    pipeline.add(caps)
    pipeline.add(encoder)
    pipeline.add(rtppay)
    pipeline.add(sink)
    streammux.link(tiler)
    tiler.link(pgie)
    pgie.link(converter)
    converter.link(capsfilter)
    capsfilter.link(osd)
    osd.link(nvvidconv_postosd)
    nvvidconv_postosd.link(caps)
    caps.link(encoder)
    encoder.link(rtppay)
    rtppay.link(sink)
    # Create sources as before, using create_uridecode_bin function
    sources = [None, None, None, None]
    for idx in range(4):
        sources[idx] = 'rtsp://' + str(cctv_id[idx]) + ':' + str(cctv_pw[idx]) + '@' + \
                     str(ip[idx]) + ':' + str(port[idx]) + '/profile2/media.smp'
    for idx, source in enumerate(sources):
        source_bin = create_uridecode_bin(idx, source, streammux)
        pipeline.add(source_bin)
        source_bin.sync_state_with_parent()
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    bus.connect('message', bus_call, loop)
    # Connect custom probe function to pgie src pad
    pgie_src_pad = pgie.get_static_pad('src')
    if not pgie_src_pad:
        sys.stderr.write('ERROR: Failed to get pgie src pad\n')
        sys.exit(1)
    else:
        pgie_src_pad.add_probe(Gst.PadProbeType.BUFFER, tracker_src_pad_buffer_probe, 0)
    srcpad = capsfilter.get_static_pad("src")
    if not srcpad:
        sys.stderr.write('ERROR: Failed to get streammux src pad\n')
        sys.exit(1)
    else:
        reconnect_flags = [False, False, False, False]
        srcpad.add_probe(Gst.PadProbeType.BUFFER, tiler_src_pad_buffer_probe, reconnect_flags)
    rtsp_port_num = 18555
    server = GstRtspServer.RTSPServer.new()
    server.props.service = "%d" % rtsp_port_num
    server.attach(None)
    factory = GstRtspServer.RTSPMediaFactory.new()
    factory.set_launch(
        '( udpsrc name=pay0 port=%d buffer-size=%d caps="application/x-rtp, media=video, clock-rate=90000, '
        'encoding-name=(string)%s, payload=96 " )'
        % (udpsink_port_num, buf_size, 'H264')
    factory.set_shared(True)
    server.get_mount_points().add_factory("/ds-test", factory)
    print(
        "\n *** DeepStream: Launched RTSP Streaming at rtsp://localhost:%d/ds-test ***\n\n"
        % rtsp_port_num
    pipeline.set_state(Gst.State.PLAYING)
The ROI method is not what I am looking for. I am sharing the link to the paper of the new model I found: https://arxiv.org/pdf/2403.09281v1
To summarize the image processing method:
  1. Image Segmentation: The large image is divided into smaller blocks, and each block is processed individually. This allows for better capture of details in the entire image.
  2. Block-level Classification: Each block is assigned to a specific class (crowd count) using the CLIP model. This provides a more accurate understanding of the crowd density in the entire image.
  3. Synthesis: The results of all blocks are combined to generate a final density map for the entire image.
I am trying to implement this process in DeepStream, and I am curious if it is possible to implement the image segmentation feature.
  1. what is your Image Segmentation model? what do you mean about “divided into smaller blocks”? does model output bbox or mask?
  2. about Synthesis, you can add a probe function on nvinfer ’ src, then add the custom code in the probe function.
