How to custom message to a broker with image metadata in DeepStream?
This is just a general question. I haved tested and deployed DeepStream with a customed model successfully. But when I attached message broker configuration and run by deepstream-test5-app. The broker has not received any information about the frame that the model inferenced on: (object appearance, etc…)
Is there any way we can custom and send the message with these image metadata? An example code for modifying this config would be nice!
The feature is in our roadmap. It will be available in future DS release. Thanks.
So… there is no way for us to customize message to broker by now, right?
You also can do it by yourself as it is open source plugin.
