I use deepstream to enable four cameras for object detection and tracking. However, sometimes the entire screen gets stuck. After using the kill command to kill the process and reopening the program, it doesn’t work properly. When viewed with the command ps-aux at grep “D”, root 462 0.2 0.0 0 0? The result of D 08:56 0:03 [kworker/0:4+events] shows that the process can only be killed by restarting the device and re-running the program. I want to know the cause of this zombie process and how to kill it without restarting the system to ensure that my program gets stuck. I can restart the device through the software level
• DeepStream Version
• TensorRT Version
• The pipeline being used
Hardware platform: Jetson Orin NX
DeepStream version:deepstream-app version 7.0.0 DeepStreamSDK 7.0.0
JetPack version:Jetpack: 6.0
TensorRT version:8.6.2.3
problem types:When I connected four Hikvision cameras using deepstream, I encountered a situation where the real-time detection got stuck. After stopping the program by pressing ctrl+c, I used kill to kill the python process. Then restart the code, but it cannot be detected normally. When the detection is enabled, the screen goes black. In the process search, there is the D 08:56 0:03 [kworker/0:4+events] process. Only by forcibly shutting down can the program be restarted.
The real-time stream is at 2k resolution. Now it is suspected that the kernel process is stuck due to incorrect loading of the real-time stream
Pipe code:
#!/usr/bin/env python3
import sys
import os
from pathlib import Path
sys.path.append(os.path.dirname(os.path.dirname(os.path.abspath(__file__))))
import debug_logger
sys.path.append('../../')
sys.path.append(str(Path(__file__).resolve().parent))
import configparser
import gi
gi.require_version('Gst', '1.0')
gi.require_version('GstRtspServer', '1.0')
from gi.repository import GLib, Gst, GstRtspServer
from common.platform_info import PlatformInfo
import os
os.environ["GST_DEBUG_DUMP_DOT_DIR"] = "./tmp"
os.putenv('GST_DEBUG_DUMP_DIR_DIR', 'tmp')
from gtyStreamUtils import *
from gtyOsdProbe import *
from gtyTilterProbe import *
from gtyNvvidconv1Probe import *
from multiprocessing import Lock
os.system("export GST_DEBUG=\"deepstream*:WARNING\"")
bitrate = 4000000
from colorama import Fore
from gtyIO import gtyLog
def main(eventQ=None):
debug_logger.log_now("STREAM", "Stream Process Launched. Preparing pipeline...")
gtyLog.logger.info(Fore.GREEN+"====================Stream started=================="+Fore.RESET)
configHandler = gtyConfig.ConfigFileHandler()
if not configHandler.saftyCheck:
gtyLog.logger.critical(Fore.RED+"safty check failed..."+Fore.RESET)
return
sourceUrls, frameWidth, frameHeight = loadSourceConfig(configHandler)
# 统计源的数量
number_sources = len([s for s in sourceUrls if s])
tilterOutputWidth = configHandler.read("display", "tilterOutputWidth", "int", 960)
tilterOutputHeight = configHandler.read("display", "tilterOutputHeight", "int", 540)
asFastAsPossible = configHandler.read("display", "asFastAsPossible", "int", 1)
lock = Lock()
outputPath = ''
while True:
with lock:
if eventQ and not eventQ["STREAM"].empty():
event = eventQ['STREAM'].get(block=True, timeout=1)
if event[0] == 'outputPath':
outputPath = event[1]
time.sleep(0.1)
break
is_live = any(
(isinstance(url, str) and url.lower().startswith("rtsp://"))
for url in sourceUrls
platform_info = PlatformInfo()
GObject.threads_init()
Gst.init(None)
#一、创建不同的组件
pipeline = Gst.Pipeline()
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
pipeline.add(streammux)
streammux.set_property("batched-push-timeout", int(1000000 / 60))
uri_decode_bins = []
src_index = 0
for i, sourceUrl in enumerate(sourceUrls):
if not sourceUrl:
continue
# 如果是文件夹模式(list),直接传整个列表;否则包装成列表
urls = sourceUrl if isinstance(sourceUrl, list) else [sourceUrl]
source_bin, uri_decode_bin = create_source_bin(src_index, Gst, urls, outputPath)
uri_decode_bins.append(uri_decode_bin)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname = f"sink_{src_index}"
sinkpad = streammux.request_pad_simple(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad = source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
src_index += 1
queue1 = Gst.ElementFactory.make("queue", "queue1")
queue2 = Gst.ElementFactory.make("queue", "queue2")
queue3 = Gst.ElementFactory.make("queue", "queue3")
queue4 = Gst.ElementFactory.make("queue", "queue4")
queue5 = Gst.ElementFactory.make("queue", "queue5")
queue6 = Gst.ElementFactory.make("queue", "queue6")
queue7 = Gst.ElementFactory.make("queue", "queue7")
queue8 = Gst.ElementFactory.make("queue", "queue8")
queue9 = Gst.ElementFactory.make("queue", "queue9")
queue10 = Gst.ElementFactory.make("queue", "queue10")
queue11 = Gst.ElementFactory.make("queue", "queue11")
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
tracker = Gst.ElementFactory.make("nvtracker", "tracker")
sgie1 = Gst.ElementFactory.make("nvinfer", "secondary1-nvinference-engine")
caps1 = Gst.Caps.from_string("video/x-raw(memory:NVMM), format=RGBA")
filter1 = Gst.ElementFactory.make("capsfilter", "filter1")
tilterRowNum = int((number_sources-1)/2)+1
tilterColNum = 2
# 将视频编码流合成为2d切片,并将流数据转换为I420
if number_sources > 1:
tiler = Gst.ElementFactory.make("nvmultistreamtiler", "nvtiler")
pipeline.add(tiler)
nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "convertor")
nvosd = Gst.ElementFactory.make("nvdsosd", "onscreendisplay")
tee = Gst.ElementFactory.make("tee","tee")
nvvidconv_postosd = Gst.ElementFactory.make("nvvideoconvert", "convertor_postosd")
caps = Gst.ElementFactory.make("capsfilter", "filter")
caps.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM), format=I420"))
encoderRecord = Gst.ElementFactory.make("nvv4l2h264enc", "encoderRecord")
nvvidconv1 = Gst.ElementFactory.make("nvvideoconvert", "convertor1")
# 对于不同的平台,创建不同的终点
# nv3dsink 用于将视频通过GPU加速显示到屏幕,是渲染输出的重要插件
sink = Gst.ElementFactory.make("nv3dsink", "nv3d-sink")
# 保存到文件的组件
tee2 = Gst.ElementFactory.make("tee","tee2")
h264parse = Gst.ElementFactory.make("h264parse", "h264-parse")
splitMuxSink = Gst.ElementFactory.make("splitmuxsink","splitmuxsink")
# 输出到udp前台页面组件
rtph264pay = Gst.ElementFactory.make("rtph264pay")
udpSink = Gst.ElementFactory.make("udpsink")
pipeline.add(queue1)
pipeline.add(queue2)
pipeline.add(queue3)
pipeline.add(queue4)
pipeline.add(queue5)
pipeline.add(queue6)
pipeline.add(queue7)
pipeline.add(queue8)
pipeline.add(queue9)
pipeline.add(queue10)
pipeline.add(queue11)
pipeline.add(pgie)
pipeline.add(tracker)
pipeline.add(sgie1)
pipeline.add(nvvidconv)
pipeline.add(filter1)
pipeline.add(nvvidconv1)
pipeline.add(nvosd)
pipeline.add(sink)
pipeline.add(tee)
pipeline.add(nvvidconv_postosd)
pipeline.add(caps)
pipeline.add(encoderRecord)
#保存到文件的组件
pipeline.add(tee2)
pipeline.add(h264parse)
pipeline.add(splitMuxSink)
# 输出到udp组件
pipeline.add(udpSink)
pipeline.add(rtph264pay)
#二、设置组件属性
filter1.set_property("caps", caps1)
encoderRecord.set_property('bitrate', 10000000)
# 设置编码的预设级别,影响编码速度和输出质量 0超快1快 最大性能模式
encoderRecord.set_property('preset-level', 1)
encoderRecord.set_property('maxperf-enable', 1)
encoderRecord.set_property('insert-sps-pps', 1)
encoderRecord.set_property("insert-vui",1)
#-----设置nvvideoconvert-------
nvvidconv.set_property('compute-hw',1)
nvvidconv_postosd.set_property('compute-hw',1)
nvvidconv1.set_property('compute-hw',1)
# nvvidconv.set_property('nvbuf-memory-type',3)
# nvvidconv_postosd.set_property('nvbuf-memory-type',3)
# nvvidconv1.set_property('nvbuf-memory-type',3)
sink.set_property('async', asFastAsPossible)
sink.set_property('sync', (asFastAsPossible+1)%2)
splitMuxSink.set_property("location",
f"{outputPath}/record_{datetime.datetime.now().strftime('%Y-%m-%d_%Hh%Mm%Ss')}"+"_%04d.mp4")
splitMuxSink.set_property("max-size-time",60000000000)
# 输入视频的尺寸,这里是单个画面的输入尺寸
streammux.set_property('width', frameWidth)
streammux.set_property('height', frameHeight)
streammux.set_property('batch-size',number_sources) # 这里必须和输入的路数相同,否则会加速或减慢
streammux.set_property('batched-push-timeout', MUXER_BATCH_TIMEOUT_USEC)
streammux.set_property('buffer-pool-size',100)
streammux.set_property('attach-sys-ts',1)
streammux.set_property('compute-hw',1) #gpu1,vic2
if is_live:
gtyLog.logger.info("检测到实时视频流")
streammux.set_property('live-source', 1)
streammux.set_property('sync-inputs',0)
else:
streammux.set_property('sync-inputs',1)
# 推理器
pgie.set_property('config-file-path',
"./gtyStream/configFiles/config_jetson_infer_primary.txt")
sgie1.set_property('config-file-path',
"./gtyStream/configFiles/config_jetson_infer_secondary_bib.txt")
# 追踪器
config = configparser.ConfigParser()
config.read('./gtyStream/configFiles/dstest2_tracker_config.txt')
config.sections()
for key in config['tracker']:
if key == 'tracker-width' :
tracker.set_property('tracker-width', config.getint('tracker', key))
if key == 'tracker-height' :
tracker.set_property('tracker-height', config.getint('tracker', key))
if key == 'gpu-id' :
tracker.set_property('gpu_id', config.getint('tracker', key))
if key == 'll-lib-file' :
tracker.set_property('ll-lib-file', config.get('tracker', key))
if key == 'll-config-file' :
tracker.set_property('ll-config-file', config.get('tracker', key))
tracker.set_property('user-meta-pool-size', 640)
nvosd.set_property('process-mode',0) # 0,cpu模式;1,gpu模式;2.vic模式
udpSink.set_property('host','127.0.0.1')
udpSink.set_property('port',5599)
udpSink.set_property('async', asFastAsPossible)
udpSink.set_property('sync', (asFastAsPossible+1)%2)
tiler.set_property("rows", tilterRowNum)
tiler.set_property("columns",tilterColNum)
# 这里是画面的总高度、宽度
tiler.set_property("width", tilterOutputWidth*tilterColNum)
tiler.set_property("height", tilterOutputHeight*tilterRowNum)
tiler.set_property("compute-hw", 1) #gpu 1, vic 2
#三、连接管道上组件
streammux.link(queue1)
queue1.link(pgie)
pgie.link(queue2)
queue2.link(tracker)
# tracker 的输出现在先连接到清晰度分类器
tracker.link(sgie1)
sgie1.link(queue3)
queue3.link(nvvidconv1)
nvvidconv1.link(queue4)
queue4.link(filter1)
filter1.link(queue5)
if number_sources>1:
queue5.link(tiler)
tiler.link(nvvidconv)
else:
queue5.link(nvvidconv)
nvvidconv.link(queue6)
queue6.link(nvosd)
nvosd.link(queue7)
queue7.link(tee)
tee.link(queue8)
queue8.link(sink)
# 对视频进行编码
tee.link(queue9)
queue9.link(nvvidconv_postosd)
nvvidconv_postosd.link(caps)
caps.link(encoderRecord)
encoderRecord.link(tee2)
# 输出到文件
tee2.link(queue11)
queue11.link(h264parse)
h264parse.link(splitMuxSink)
# 输出到udpSink
tee2.link(rtph264pay)
rtph264pay.link(udpSink)
#四、创建主循环
# create and event loop and feed gstreamer bus mesages to it
loop = GLib.MainLoop()
bus = pipeline.get_bus()
bus.add_signal_watch()
def sendEvent(task, eventName, eventData=None):
if eventData is None:
eventData = []
e = [eventName, eventData]
try:
if task.upper() in eventQ.keys():
eventQ[task.upper()].put(e)
print("--------------------------")
except Exception as e:
print(44, e)
def bus_call(bus, message, loop):
t = message.type
if t == Gst.MessageType.EOS:
gtyLog.logger.info("End-of-stream")
loop.quit()
elif t == Gst.MessageType.ERROR:
err, debug = message.parse_error()
gtyLog.logger.error(f"Error_test: {err}, Debug: {debug}")
debug_logger.log_now("STREAM", f"!!! PIPELINE ERROR: {err} | Debug: {debug} !!!")
# 这里可以重启特定的source或整个管道
loop.quit()
elif t == Gst.MessageType.WARNING:
warn, debug = message.parse_warning()
gtyLog.logger.warning(f"Warning_test: {warn}, Debug: {debug}")
debug_logger.log_now("STREAM", f"Pipeline Warning: {warn}")
sendEvent("SOCKET", "socket_ossupload",
["warning_io", str(warn)])
return True
# 在 bus.add_signal_watch() 后添加的异常总线回调部分
bus.connect("message", bus_call, loop)
gtyData={
# osd 参数
"osdFrameCounter":0,
# 画面比例调整系数
"T":Transformer(frameWidth,frameHeight,tilterOutputWidth,tilterOutputHeight),
# 运动员识别
"runnersInFrame": [None,None,None,None],
"runnersTracking": [RunnersTracking(0,eventQ),RunnersTracking(1,eventQ),
RunnersTracking(2,eventQ),RunnersTracking(3,eventQ)],
"last5FrameTime":time.perf_counter(),
"fps":25,
"sourceFps":[{"last5Time":0,"counter":0,"fps":30},
{"last5Time":0,"counter":0,"fps":30}],
"Gst":Gst,
"platform_info":platform_info,
"originalFrameSize":{"width":frameWidth,"height":frameHeight},
"sourceNum":number_sources,
"eventQ":eventQ
#nvvidconv1回调函数
nvvidconv1.get_static_pad("sink").add_probe(Gst.PadProbeType.BUFFER, nvvidconv1_sink_pad_buffer_probe, gtyData)
# 增加tilter回调函数
tiler.get_static_pad("sink").add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, gtyData)
else:
nvvidconv.get_static_pad("sink").add_probe(Gst.PadProbeType.BUFFER, tiler_sink_pad_buffer_probe, gtyData)
# 增加osd回调函数
nvosd.get_static_pad("sink").add_probe(Gst.PadProbeType.BUFFER, osd_sink_pad_buffer_probe, gtyData)
# 在管道状态变化或异常时调用:
# Gst.debug_bin_to_dot_file(pipeline, Gst.DebugGraphDetails.ALL, "pipeline_snapshot")
# 启动流水线
pipeline.set_state(Gst.State.PLAYING)
def stop_pipeline(pipeline):
"""停止GStreamer管道并释放资源"""
for uri_decode_bin in uri_decode_bins:
uri_decode_bin.emit('stop-sr', 0)
if pipeline:
pipeline.set_state(Gst.State.NULL)
pipeline = None
try:
loop.run()
except KeyboardInterrupt:
gtyLog.logger.debug("keyboard interrupt received, shutting down")
# for uri_decode_bin in uri_decode_bins:
# uri_decode_bin.emit('stop-sr',0)
gtyLog.logger.debug(f"An unexpected error: {e}")
finally:
# 清理和释放资源
# pipeline.set_state(Gst.State.NULL)
# cleanup
if __name__ == '__main__':
sys.exit(main(sys.argv))
This might be related to your signal handling function, which caused the pipeline to not be properly killed by the system, leading to subsequent problems.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
