externalSemaphoreSignalParams
{params={fence={value=6 } nvSciSync={fence=0x0000000000000000 {…} reserved=0 } keyedMutex={key=0 } …} …}
cudaExternalSemaphoreSignalParams
params
{fence={value=6 } nvSciSync={fence=0x0000000000000000 reserved=0 } keyedMutex={key=0 } …}
cudaExternalSemaphoreSignalParams::
fence
{value=6 }
cudaExternalSemaphoreSignalParams::::
nvSciSync
fence
0x0000000000000000
void *
reserved
0
unsigned __int64
keyedMutex
{key=0 }
key
0
unsigned __int64
reserved
0x000000aac79fca58 {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
unsigned int[12]
flags
0
unsigned int
reserved
0x000000aac79fca8c {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0}
unsigned int[16]
This is the loc: CudaD3D12Update/simpleD3D12update.cpp at cd59b7d6eb635a564df88c2528f42f5a8a9a5ba0 · mprevot/CudaD3D12Update · GitHub
(I actually have a different kernel, which is triggered by a c# WPF app, but the rest is the same.)
Is there a usual way to debug such problem ? In my case, I most of the time do not have invalid value, so I am surprised to get this sometimes .
Driver is 566.26, cuda is 12.6.3, OS is W10 19045.5247
veraj
January 8, 2025, 10:04am
2
Hi, @Gatchan
Sorry for the issue you met. Can you provide the step to repro this ?
Also please clarify which CUDA/GPU/Driver do you use ?
Thanks. I updated the OP with details. Aren’t the values provided sufficient ? why not ?
Hello Gatchan and thank you for bringing this issue to our attention. I’m trying to understand if your question is regarding the API or the debugger. In other words:
If you are wondering what the correct values for the members of externalSemaphoreSignalParams should be, then that is an API question and I can help route your question to the relevant team.
But if you believe you have values in the member that the debugger is showing incorrectly, then that’s a question for us, the debugger team.
From what I can tell, it seems like the first case. Can you please confirm so I can pull in the right time for further help?
Thank you
EP
Many thanks for those opportunities.
It appears that the wrong values come from a previous kernel.
I am now in familiar grounds.
Many thanks again EP.
Our pleasure! 🙂 As always, we look forward to hearing from you how to further improve our products!
Kind regards from NVIDIA!
veraj
Closed
January 31, 2025, 8:39pm
8
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
