Dear Cuda Developers,
I have a problem with debugging my code. I have a mixed code (openCV and cuda). I’m working with cuda 5.0 and a device with compute cap 3.0 and opencv 2.4.2. Furthermore I’m using Visual Studio 2010 and Nsight Monitor 2.2.0.
When I start to debug my code (using VS-debugger) everything seems to work quite well until it I’m reaching the level where I call functions from my cu-files. At this point I’m not able to debug any more, obviously.
When I’m using my the nsight-dubugger I’m getting the same error message (R6010- -abort()has been called) while doing my init part (where I’m mainly using some opencv calls to a allocate memory (GpuMat and CudaMem)). But of course I’m not ably to see that is happening exactly, because I not able to debug it.
Does someone else can give us an advice how to debug this kind of code, please?
Thank you very much for any hint in advance.
cheers Greg
