Hey @jchaves and thanks for your answer !
In the link your provided, it’s explicitly said that this format is not documented :
To display the RAW bayer or debayered frames you could use GStreamer or vooya.
As far as I know nor GStreamer or Vooya supports padded 12 bit Bayer raw image.
In case you are looking for alternatives to the NVIDIA Argus software stack currently there is support for debayering using the GstCuda element.
I might be interested if it supports this particular format, but it is not available yet it seems.
Can someone from Nvidia chime in and give a clear description of the bytes I see in this file ? @JerryChang @ShaneCCC?
It’s clearly not any of those:
It is also not
d11 | d10 | d09 | d08 | d07 | d06 | d05 | d04 | d03 | d02 | d01 | d00 | d11 | d10 | d09 | d08 |
Because of the following pixel:
00001111 11111110
Or am I missing something ?
