How to Deepstream TensortRT version upgrade
root@soohyeon-HP-Z2-Tower-G5-Workstation:/dev# v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
	Type: Video Capture
	[0]: 'YUYV' (YUYV 4:2:2)
			Interval: Discrete 0.033s (30.000 fps)
			Interval: Discrete 0.040s (25.000 fps)
			Interval: Discrete 0.050s (20.000 fps)
			Interval: Discrete 0.067s (15.000 fps)
			Interval: Discrete 0.100s (10.000 fps)
			Interval: Discrete 0.200s (5.000 fps)
			Interval: Discrete 0.133s (7.500 fps)
	[1]: 'MJPG' (Motion-JPEG, compressed)
from the log “failed delayed linking”, the Gstreamer negotiation failed. it is because nvvideoconvert can’t support YUYV format. you can “gst-inspect-1.0 nvvideoconvert” to check.
you can use videoconvert to convert the YUYV to a format that nvvideoconvert supports. please try “gst-launch-1.0 uridecodebin uri=v4l2:///dev/video0 ! videoconvert ! nvvideoconvert ! autovideosink” or “gst-launch-1.0 -v uridecodebin uri=v4l2:///dev/video0 ! videoconvert ! video/x-raw,format=\(string\)YVYU ! nvvideoconvert ! autovideosink”
Really thank you Through this command, the gst is is working normally.
If so, it’s the last step. How to apply this to deepstream-yolov4?
deepstream_tao_apps is opensource. you can add a videoconvert plugin between uridecodebin and nvvideoconvert .
Thank you very much for your reply.
But I’m a beginner, so I don’t know how to apply it to my code with your answer.
Do you happen to have an example?
please refer to create_camera_source_bin in opt\nvidia\deepstream\deepstream-6.2\sources\apps\apps-common\src\deepstream_source_bin.c. this function will link videoconvert and nvvideoconvert.
