• Hardware Platform (Jetson / GPU) : jetson • DeepStream Version : 5.0 ga • JetPack Version (valid for Jetson only) : 4.4 • TensorRT Version : 7.1.x
Hi all,
If I want to have difference nvvideoconvert element for difference rtsp sources, How I can to define this? My goal is to define difference ROI(src-crop, dest-crop) property of nvvideoconvert for each RTSP stream?
In this link, all of streams have same nvvideoconvert with same property, but I want to define different property of this element for each stream.
The stream multiplexer element (nvstreammux) takes multiple incoming streams and adds them into a single one. All the converters in that example are added after the stream mux, which means they can not operate each stream individually.
You can add the croping element (videocrop or nvvideoconvert) just after the source bin (pipeline.add(source_bin)) to operate each stream before it gets into the stream mux. Here are some example pipelines:
I know this is an older post, but I found it useful. However did this completely work for you? When I use the same ROI for each stream it works fine, but when I use differents ROI’s for each stream I am getting segmentation faults, did you encounter this?
