How to deinterlace mipi-csi in Orin nano on JetPack 7.2 with Jetson Linux 39.2?
Hi NV team,
I notice that in Jetson_Linux_Release_Notes_r39.2.pdf => 4. Fixed Issues
5451745 De-interlace decode is not supported.
And in video-deinterlacing-with-gstreamer-1-0
The NVIDIA proprietary nvdeinterlace GStreamer-1.0 plugin converts interlaced video frames to progressive video frames. It supports two compute backends:
VIC (Video Image Compositor): Available on the Jetson Orin.
GPU (CUDA-based): Available on the Jetson Orin and Jetson Thor.
But I try following pipe still get interlaced image
DISPLAY=:1 gst-launch-1.0 v4l2src device=/dev/video4 ! \
  'video/x-raw, format=(string)UYVY, width=720, height=480, framerate=30/1' ! \
  rawvideoparse use-sink-caps=false format=uyvy width=720 height=480 framerate=30/1 interlaced=true ! \
  nvvidconv ! \
  'video/x-raw(memory:NVMM), format=(string)NV12' ! \
  nvdeinterlace tff=1 mode=3 ! \
  queue ! \
  nv3dsink
How can I fix this? Do we suppout deinterlaced?
Doesn’t looks like interlace problem more like alignment problem.
Could you modify the 720 to 736 that have 32 alignment to try.
