How to demangle pgCC names
To diagnose the following IPA problem (pgCC 11.9 on Linux):
The following function(s) are called, but no IPA information is available:
__CPR115____as__36AlignedAllocator__tm__12_dXCUlL_2_64FRC31AlignedAllocator__tm__8_Z1ZXZ2Z_RJ47J
I need to demangle the above routine name and the missing routine names from the linker. I’m using a custom STL allocator and I suspect I forgot a function member somewhere (btw, my allocator compiles under gcc and VC++).
c++filt does nothing (tried all options).
Thanks for your help!
mario
Answering my own question:
pgdecode
mangled name
(I was trying to use it from command line…)
mario
