I followed the instructions on Github to compile and install 5.1.5.0 and the sample googlenet passed. However it doesn’t seem to use the compiled code. I just print to the console to test it.
The binary lib has:
libnvcaffe_parser.so*
The compiled lib has:
libnvcaffeparser.so*
One has the “_” and the other doesn’t.
Please shed some lights.
It seems to be due to ENV variable setting issue.
Could you please check if “LD_LIBRARY_PATH” and other ENV variables has been updated to point to new release/code.
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$TRT_RELEASE/lib
Also, check the installed TRT packages using below command:
dpkg -l | grep TensorRT
The LD_LIBRARY_PATH is set correctly.
I followed the instructions here: https://github.com/NVIDIA/TensorRT/tree/release/5.1 which uses tar package instead of deb.
My question was why the compiled lib name is different than the binary version? Is the additional “_” intentional or that’s actually the issue I’m having?
On your installation guide it says:
The libnvcaffe_parser.so library functionality from previous versions is included in libnvparsers.so since TensorRT 5.0. The installed symbolic link for libnvcaffe_parser.so is updated to point to the new libnvparsers.so library. The static library libnvcaffe_parser.a is also symbolically linked to libnvparsers_static.a.
However, when I built 5.1.5.0 from source. The /build/out directory only contains these caffe parser files:
libnvcaffeparser.so
libnvcaffeparser.so.5.1.5
libnvcaffeparser.so.5.1.5.0
libnvcaffeparser_static.a
I can’t figure out how to overwrite the caffeparser in the lib.
Can you provide the following information so we can better help?
Provide details on the platforms you are using:
o Linux distro and version
o GPU type
o Nvidia driver version
o CUDA version
o CUDNN version
o Python version [if using python]
o Tensorflow and PyTorch version
o TensorRT version
Linux distro and version: Ubuntu 18.04.3 LTS
GPU type: GeForce RTX 2080 Ti
Nvidia driver version: 418.87.00
CUDA version: release 10.1, V10.1.243
CUDNN version: 7.5.0
Python version: 3.6.9
Tensorflow version: 1.15.0
TensorRT version: 5.1.5.0
So I’m trying to apply the patch to CaffeParser:
https://devtalk.nvidia.com/default/topic/1068181/deepstream-sdk/error-trying-to-create-engine-from-digit-trained-model-files/2
I use TensorRT Python API to build the cuda engine, but my changes doesn’t take effect.
Can you retry fresh installation using the latest TRT version?
I tried the latest version 7.0.0.11 and the changes still doesn’t take effort when I use Python API. C++ API seems to work. Is this expected? Do you have any workaround?
Could you please try your application directly on TRT 7 without applying the patch?
If issue persist, could you please share the script and model file to reproduce the issue so we can help better?
