Description
Hi all, I’m trying to deploy Grad-CAM with TRT C++ API. The deployment is divided into two steps, and I’m having trouble in step2.
- Step1: forward inference, which is easy to do using TRT.
- Step2: perform gradient backward, I didn’t find a reference example or API in TRT.
The step2 in pytorch:
- use register_backward_hook() to mark the desired gradient position
- call loss.backward() function for gradient backward
- use hook to get the gradient as a heatmap
how can I use TRT to do this?
Thanks in advance.
Part of the code, the full implement is in Relevant Files
class GradCAM:
def __init__(self, arch: torch.nn.Module, target_layer: torch.nn.Module):
self.gradients = dict()
def backward_hook(module, grad_input, grad_output):
self.gradients['value'] = grad_output[0]
target_layer.register_backward_hook(backward_hook)
def forward(self, input, class_idx=None, retain_graph=False):
logit = self.model_arch(input)
score = logit[:, class_idx].squeeze()
score.backward(retain_graph=retain_graph)
gradients = self.gradients['value']
def __call__(self, input, class_idx=None, retain_graph=False):
return self.forward(input, class_idx, retain_graph)
Environment
TensorRT Version: 10.9.0
GPU Type: A100
Nvidia Driver Version: 535.104.12
CUDA Version: 12.2
CUDNN Version: 8.9.7
Operating System + Version: CentOS
Python Version (if applicable): N.A.
TensorFlow Version (if applicable): N.A.
PyTorch Version (if applicable): 2.4.1
Baremetal or Container (if container which image + tag): N.A.
Relevant Files
Similar topic in the forum, but no solution for step2:
Grad-CAM paper:
https://arxiv.org/pdf/1610.02391
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
