How to deploy the development environment in the deepstream-l4t container
After deploying the l4t container, I found that NVIDIA’s header file library files are missing when developing on it. How should I install these libraries?
• DeepStream Version
• TensorRT Version
• The pipeline being used
I don’t know what headers and libraries you want, nor what versions you use.
Please describe your problem in detail
When I compiled my project, I found that related files such as NvInfer.h and cuda_runtime_api.h did not
This is my host environment, I need to build my deepstream application in the Deepstream-l4t container
Distribution: ubuntu 20.04 focal
Python : 3.8.10
CUDA:11.4.315
cuDNN :8.6.0.166
TensorRT :8.5.2.2
VPI:2.2.7
OpenCV:4.5.4
Model:NVIDIA Orin NX Developer Kit
Module:NVIDIA Jetson Oriin NX(16GB ram)
Jetpack:5.1.1
DeepStream: 6.2
Do you use nvcr.io/nvidia/deepstream-l4t:6.2-iot this images ?
If you want build your deepstream application
It is recommended to use the image of nvcr.io/nvidia/deepstream-l4t:6.2-triton
Here are their differences.
nvcr.io/nvidia/deepstream-l4t:6.2-iot just for deployment
You can also copy header files from host to docker.
I am using the image Deepstream-l4t-samples.
But I use the image of iot and there is no relevant header file
