How to design a pipeline with multiple flows and inference routes
I have a scenario where when I add a camera, I need to control the AI function enabled by the camera, then choose which queues to use for inference, and finally publish a message through mqtt
I don’t know how to design with Deepstream
• DeepStream Version
• TensorRT Version
can you provide the information above?
what do you mean about “I need to control the AI function enabled by the camera”? what is the models used to do? could you provide a media pipeline or graph to describe the requirements? Thanks!
About inference and sending mqtt, please refer to ready-made example deepstream-test5.
I’m sorry I didn’t explain clearly. I’m wondering if we can use custom source caps to send data to different streammux instances. Each streammux would then be followed by a different inference pipeline, allowing us to build a dynamic and multifunctional pipeline.
nvstreammux already support dynamically add and delete sources. please refer to sample runtime_source_add_delete. there are more questions.
Okay, you’re right, thank you
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks!
