To identify the eMMC manufacturer and model during the firmware flashing process on the Jetson AGX Orin, you can use the following methods:
- Using the
mmc command: You can use the mmc command to retrieve information about the eMMC device. Specifically, you can use the mmc extcsd read command to read the Extended CSD (eCSD) register, which contains information about the eMMC device, including the manufacturer and model.
Here’s an example of how to use the mmc command:
$ mmc extcsd read /dev/mmcblk0
This will output a list of information about the eMMC device, including the manufacturer and model.
- Using the
mtd command: You can use the mtd command to retrieve information about the eMMC device. Specifically, you can use the mtd info command to retrieve information about the eMMC device, including the manufacturer and model.
Here’s an example of how to use the mtd command:
$ mtd info /dev/mmcblk0
- Parsing the kernel logs: You can also parse the kernel logs to retrieve information about the eMMC device. Specifically, you can look for the
mmc driver logs, which will contain information about the eMMC device, including the manufacturer and model.
Here’s an example of how to parse the kernel logs:
$ dmesg | grep mmc
This will output a list of logs related to the mmc driver, including information about the eMMC device.
- Using the
nvme command: If you are using an NVMe storage device, you can use the nvme command to retrieve information about the device. Specifically, you can use the nvme id-ctrl command to retrieve information about the device, including the manufacturer and model.
Here’s an example of how to use the nvme command:
$ nvme id-ctrl /dev/nvme0
This will output a list of information about the NVMe device, including the manufacturer and model.
Comparison of methods:
- The
mmc command is the most straightforward method to retrieve information about the eMMC device.
- The
mtd command provides more detailed information about the eMMC device, but it may require more expertise to parse the output.
- Parsing the kernel logs can provide valuable information about the eMMC device, but it may require more expertise to parse the output.
- The
nvme command is specific to NVMe storage devices and provides detailed information about the device.
Conclusion:
To identify the eMMC manufacturer and model during the firmware flashing process on the Jetson AGX Orin, you can use the mmc command, mtd command, parse the kernel logs, or use the nvme command (if using an NVMe storage device). The mmc command is the most straightforward method, while the mtd command and parsing the kernel logs provide more detailed information.
