How to determine if buffer is a key-frame using pyds
NA
• DeepStream Version
6.2 and 6.3
NA
• TensorRT Version
NA
NA
Just a question… if one has
def tiler_sink_pad_buffer_probe(pad, info, u_data):
    gst_buffer = info.get_buffer()
how can you tell if gst_buffer is a key_frame?
I saw a comment on the gstreamer boards that indicated the following works in C
if(!GST_BUFFER_FLAG_IS_SET(buffer, GST_BUFFER_FLAG_DELTA_UNIT))
// it's a keyframe
Is there a way in Python?
Thanks,
Robert.
I am not 100% sure if this would work, but from the document it seems there is a function named Gst.Buffer.has_flags
So in your example, probably doing
if gst_buffer.has_flags(Gst.BufferFlags.DELTA_UNIT):
might work.
In fact,The flag of the key frame is meaningful only before decoding.
Take deepstream_test_1.py as an example,the following code can get the results.
In the tiler sink probe function, it is impossible to get the key frame tag, it is meaningless.
+def parser_src_pad_buffer_probe(pad,info,u_data):
+    gst_buffer = info.get_buffer()
+    if not gst_buffer:
+        print("Unable to get GstBuffer ")
+        return Gst.PadProbeReturn.ERROR
+    if gst_buffer.has_flags(Gst.BufferFlags.DELTA_UNIT) == False:
+        print("key frame ")
+    return Gst.PadProbeReturn.OK
+    parsersrcpad = h264parser.get_static_pad("src")
+    if not parsersrcpad:
+        sys.stderr.write(" Unable to get src pad of h264parser \n")
+    parsersrcpad.add_probe(Gst.PadProbeType.BUFFER, parser_src_pad_buffer_probe, 0)
Thanks @marmikshah and @junshengy … very helpful!
