How to develop Deepstream application from Ubuntu Host machine?
I am developing a deepstream application on jetson nano. But I want to continue development from my Ubuntu 20 Host machine, because I can access AI tools in my environment. Currently I am trying to install Deepstream correctly. Actually I installed but I am getting some errors like:
pgie = Gst.ElementFactory.make("nvinfer", "primary-inference")
if not pgie:
    sys.stderr.write("Unable to create pgie\n")
Here pipeline could not find nvinfer
or
streammux = Gst.ElementFactory.make("nvstreammux", "Stream-muxer")
if not streammux:
    sys.stderr.write("Unable to create NvStreamMux\n")
Here the nvstreammux is not found.
Are these pipeline elements special for Jetson devices? What is the best practice for developing deepstream application? Should i use Jetson as a development environment?
• Hardware Platform (Jetson / GPU) Jetson nano
• DeepStream Version 6
• JetPack Version (valid for Jetson only) 4
• TensorRT Version 8
• Issue Type( questions, new requirements, bugs) Questions
No, If you install the DeepStream SDK correctly, it should work on both jetson/x86
It is recommended to use Docker to avoid complicated installation process
Using Jetson as a development environment is best practice, as some plugins only work on Jetson/X86.
But it is very easy to develop on X86 and then port to Jetson, with only very minor differences.
