Please explain what for dict file?
I removed some symbols for better cyrillic recognition but it works very bad. E detects as H now.
Example: Q never appears on car plate so i want delete it from dict. Otherwise sometimes O becomes Q.
It is default us dict.txt. For example if i remove Q then how it works?
I got it. I should not delete lines. I should replace Q with O.
Solved.
