How to disable mqtt broker logs
• Hardware Platform Jetson
• DeepStream Version 6.3
• JetPack Version 5.1.2
• TensorRT Version
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m242, 'etas/v2x', ... (2460 bytes))
Publish callback with reason code: Success.
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m243, 'etas/v2x', ... (2993 bytes))
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m244, 'etas/v2x', ... (3000 bytes))
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m245, 'etas/v2x', ... (2988 bytes))
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m246, 'etas/v2x', ... (2984 bytes))
[mosq_mqtt_log_callback] Client uniqueID sending PUBLISH (d0, q0, r0, m247, 'etas/v2x', ... (2450 bytes))
You can’t disable it as it need change source code. What is the impact for your project? Can you redirect it to the /dev/null?
Because I have lot of output to mqtt. And those output will impact my useful log info. And I also doubt will it impact some performance with so much log output.
Any news on this? The former Paho based client was available as source code and adaptable. We have here the same issues with this nvds mqtt client, that the unwanted logs have an impact on performance and make our logs hard to handle …
