How to disable nvccp camera power control?
I have a custom board with Xavier. I installed Drive OS 5.2.0 and Driveworks 3.5. I would like to run a sample application “sample_camera”. And it complains about camera power control as below.
[09-03-2021 10:35:21] CameraMaster::setOutputDescription Setting output consumer descriptors for sensor: OutputType: 1
[09-03-2021 10:35:21] Client, setting pipeline config for camera ID 0
[09-03-2021 10:35:21] CameraMaster: master initiation
AURIX_IP or INTERFACE or both missing…
falling back to env variable check …
DEVBLK_WORKER_0: pwr_utils.cpp: 196: PowerControlRequestOwnership: PowerControlRequestOwnership: nvccp_request_ownership failed with status (1001)
DEVBLK_WORKER_0: CNvMDeviceBlockMgr.hpp: 147: ThreadFunc: Device block init failed(7f)
sample_camera: CNvMDeviceBlockMgr.cpp: 129: WorkersDoAction: Device block action:1 failed for block:0
sample_camera: CNvMDeviceBlockMgr.cpp: 163: Init: Failed to initialize device blocks
I have only a Xavier, desieralizer MAX96712 and Entron camera and they are always ON.
Does anybody know how to bypass or disable camera power control on Driveworks?
Dear @youngsouck.eun ,
Moving topic to DRIVE AGX forum(DRIVE AGX General - NVIDIA Developer Forums)
Could you share the camera model and command? Also, could you confirm if the sample is working with others?
Could you provide any update to move this topic?
