There was a problem porting the x86/x64 FPGA based PCIe device driver to nvidia.
The driver uses the remap_pfn_range function, where one of the function arguments is the page number obtained using virt_to_pfn.
When call mmap from userspace, the system goes into a reboot. I tried getting the page number with page_to_pfn(virt_to_page(virt_address)) and PHYS_PFN(phys_address) but that didn’t help.
After reading the forum, I found that the problem is in the enabled SMMU. But I couldn’t find a way to turn it off.
Could someone write here a step-by-step instruction on how to disable the SMMU?
please read
I couldn’t find where to download the source dts.
Can you tell me where to download it from?
And is it possible to compile and apply the new dtb directly from Linux running on the board?
please check this website. Select the l4t version you are using and download the code.
You need to flash it to update dtb.
