ie all the TVMR: xxx
messages
Looking for some kind of silent=true option but cannot see one with gst-inspect-1.0
Many thanks
Mark
messages
Many thanks
Mark
Have you tried passing -q to gst-launch-1.0 ?
gst-launch-1.0 --help
Usage:
gst-launch-1.0 [OPTION...] PIPELINE-DESCRIPTION
Help Options:
-h, --help Show help options
--help-all Show all help options
--help-gst Show GStreamer Options
Application Options:
-t, --tags Output tags (also known as metadata)
-c, --toc Output TOC (chapters and editions)
-v, --verbose Output status information and property notifications
[b] -q, --quiet Do not print any progress information
[/b] -m, --messages Output messages
-X, --exclude=PROPERTY-NAME Do not output status information for the specified property if verbose output is enabled (can be used multiple times)
-f, --no-fault Do not install a fault handler
-e, --eos-on-shutdown Force EOS on sources before shutting the pipeline down
--version Print version information and exit
You may also read https://developer.ridgerun.com/wiki/index.php/GStreamer_Debugging#Use_standard_GStreamer_debug_output_with_filter
If you’re not using gst-launch, you can try to filter your application’s output with
your_gst_app | grep -v "TVMR:"
or something equivalent with sed.
Furthermore, I’m not sure TVMR messages come from nvvidconv. May be h264 related ?
Hi - I am using gst-parse-launch() from inside python - I don’t see a quiet option on that function call. But great idea!
M
You could try adding this to your pipeline:
--gst-debug=*:0 <your pipeline>
or
--gst-debug=nvvidconv:0 <your pipeline>
for just having no debug output from nvvidconv.
