My app work on drm mode. I sudo systemctl set-default multi-user.target
. I know the terminal will display on the screen. I don’t want to display it. How to config it?
That is called fb console and you need to disable it from kernel config.
yes, I know. Which one I should disable.
CONFIG_DUMMY_CONSOLE=y
CONFIG_DUMMY_CONSOLE_COLUMNS=80
CONFIG_DUMMY_CONSOLE_ROWS=25
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
This one.
