Problem: I have a USB 3.0 device (Pointgrey Chameleon3 camera) that is getting its USB 3.0 LPM levels U1 and U2 enabled (and this is interfering with proper operation). Perhaps this is a bug in the kernel, because this happens with R23.2.0 but not with R24.2.1. It also only happens (with R23.2.0) when I have the camera connected directly to the TX1, but not when connected via an (unpowered) hub.
Plenty out there on disabling autosuspend (which doesn’t help), but I’m having difficulty finding information on how to disable LPM.
Hi zqpm,
We strongly suggest you migrate to the latest r24.2.1.
However, if you inevitably have to stay on r23.2, probably you can try to port the FW and source code of xhci driver from r24.2.1 to r23.2:
FW path:
/lib/firmware/tegra21x_xusb_firmware
xhci driver:
kernel\drivers\usb\host\xhci*
