I need to disable vertical synchronization on around 300 PCs in corporate environment and I can’t find a way to disable it through Windows Registry settings. Is there any way to disable vsync through Windows Registry key so I could write Powershell script and use it in group policy or SCCM environment?
If there is no way to disable vsync through Windows Registry can anyone suggest any other solution to solve this issue?
Thank you in advance
