How to disbable the usb network,just use the mass storage function?
Hello
we want to disable the usb network for J512, just use the mass storage function.How to configure the software ?
The content for the device mode setup is here:
/opt/nvidia/l4t-usb-device-mode
The files are plain human readable script. I’ll suggest saving a backup, and then just editing to comment out the USB network side. Then restart.
Hello linuxdev
we disable the driver of ucsi CONFIG_TYPEC_UCSI ,and we found that we could not find the usb in the host by use the command lsusb.How to configure the software to adapt the driver?
I could not answer that, but I suspect that there would also be a device tree change involved if you are removing a type-C PHY (the device tree was probably for type-C, and would now need to instead support a type-A for host mode…or for device mode, type-B).
Note that changing the PHY support (removing the ability of the kernel to work with type-C) is not necessary for disabling gadget mode devices. Simultaneously, removing support for a PHY requires changing driver configuration, and would be independent of gadget “virtual” devices.
