hello JerryChang:
My modifications are as follows:
diff --git a/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c b/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
index a37495c8..d3e95e28 100644
--- a/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
+++ b/kernel/nvidia/drivers/media/platform/tegra/camera/camera_common.c
@@ -85,6 +85,13 @@ static const struct camera_common_colorfmt camera_common_color_fmts[] = {
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_XRGGB10P,
+ /* GRAY */
+ MEDIA_BUS_FMT_Y10_1X10, // Gray 10-bit
+ V4L2_COLORSPACE_RAW,
+ V4L2_PIX_FMT_Y10,
struct camera_common_csi_io_pad_ctx {
diff --git a/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c b/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
index 42864af7..e24922cb 100644
--- a/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
+++ b/kernel/nvidia/drivers/media/platform/tegra/camera/sensor_common.c
@@ -214,6 +214,10 @@ static int extract_pixel_format(
*format = V4L2_PIX_FMT_XBGGR10P;
else if (strncmp(pixel_t, "bayer_xrggb10p", size) == 0)
*format = V4L2_PIX_FMT_XRGGB10P;
+ else if (strncmp(pixel_t, "gray_y10", size) == 0) {
+ *format = V4L2_PIX_FMT_Y10;
else {
pr_err("%s: Need to extend format%s\n", __func__, pixel_t);
return -EINVAL;
diff --git a/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi2_formats.h b/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi2_formats.h
index 31817030..98665566 100644
--- a/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi2_formats.h
+++ b/kernel/nvidia/drivers/media/platform/tegra/camera/vi/vi2_formats.h
@@ -127,5 +127,9 @@ static const struct tegra_video_format vi2_video_formats[] = {
YUV422_8, YUYV, "YUV 4:2:2 YUYV"),
TEGRA_VIDEO_FORMAT(YUV422, 16, YVYU8_2X8, 2, 1, T_Y8_V8__Y8_U8,
YUV422_8, YVYU, "YUV 4:2:2 YVYU"),
+ /* GRAY */
+ TEGRA_VIDEO_FORMAT(RAW10, 10, Y10_1X10, 2, 1, T_R16_I,
+ RAW10, Y10, "GRAY10"),
#endif
in .dts file:
csi_pixel_bit_depth = "10";
mode_type = "gray";
pixel_phase = "y";
v4l2-ctl --list-formats-ext Output is as follows:
nvidia@nvidia-desktop:~$ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'Y10 '
Name : 10-bit Greyscale
Size: Discrete 1456x1080
Interval: Discrete 0.017s (60.000 fps)
Applications Using GStreamer with V4L2 Source Plugin
Render the preview to a screen as follows:
nvidia@nvidia-desktop:~/workplace$ export DISPLAY=:0
nvidia@nvidia-desktop:~/workplace$ gst-launch-1.0 v4l2src device=/dev/video0 ! 'video/x-raw, format=(string)Y10, width=(int)1440, height=(int)1080, framerate=(fraction)60/1' ! xvimagesink -ev
WARNING: erroneous pipeline: could not link v4l2src0 to xvimagesink0, v4l2src0 can't handle caps video/x-raw, format=(string)Y10, width=(int)1440, height=(int)1080, framerate=(fraction)60/1
The following is successful through v4l-ctl
nvidia@nvidia-desktop:~/workplace$ v4l2-ctl --set-fmt-video=width=1440,height=1080,pixelformat=Y10 --stream-mmap --stream-count=1 -d /dev/video0 --stream-to=test.raw
< 9523809.52 fps
