I have 3 identical monitors in perfect horizontal layout (1920x1080 all@144fps), attached to one GTX1050ti.
Looks like this:
xrandr output is:
jai@jai:~$ xrandr
Screen 0: minimum 8 x 8, current 5760 x 1080, maximum 32767 x 32767
DVI-D-0 connected 1920x1080+3840+0 (normal left inverted right x axis y axis) 698mm x 393mm
1920x1080 60.00 + 144.00* 119.98 119.88 99.93 59.94 50.00 60.00 50.04
1680x1050 59.88
1280x1024 75.02 60.02
1280x720 59.94 50.00
1024x768 119.99 100.00 75.03 70.07 60.00
800x600 119.97 100.00 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 120.01 99.99 75.00 72.81 59.94 59.93
HDMI-0 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 698mm x 393mm
1680x1050 59.88
720x576 50.00
720x480 59.94
DP-0 connected primary 1920x1080+1920+0 (normal left inverted right x axis y axis) 698mm x 393mm
1920x1080 60.00 + 164.92* 144.00 119.98 119.88 99.93 59.94 50.00
1280x720 60.00 59.94 50.00
1024x768 119.99 99.97 75.03 70.07 60.00
800x600 119.97 99.66 75.00 72.19 60.32 56.25
720x576 50.00
720x480 59.94
640x480 119.52 99.77 75.00 72.81 59.94 59.93
DP-1 disconnected (normal left inverted right x axis y axis)
How can I divide it into let’s say 3 custom resolution desktops? like this:
(Obviously in this case, the middle desktop spans partially on left&right monitors and completely on the middle monitor.)
So that when I full screen a window, it will snap according to in which desktop it is.
