Hi, all
I am trying to do batch execution on this TensorRT sample code.
To do that,
I changed the code int batchSize = 1 to int batchSize = 4 as follows.
I am not sure that it is enough to make this code do batch execution.
Is there any more code I have to change for batch execution?
(Plus, Is there any way to check whether this program really does batch execution or not?)
Any help would be greatly appreciated.
Thanks in advance.
yjkim.
For reference,
main.cpp in TensorRT_sample.zip
#include "tools.h"
#include <unistd.h>
#include <fstream>
#include <vector>
#include <cassert>
#include <mutex>
#include <condition_variable>
#include <atomic>
#include <numeric>
#include <future>
#include <csignal>
#include <cstdlib>
#include <chrono>
#include <string>
using namespace nvinfer1;
class Task {
public:
Task(const char* filename, int dlaCore, int streamCreateFlag = cudaStreamDefault, int eventCreateFlag = cudaEventDefault);
void exec_once(int batchSize = 4) {
const bool success = context->enqueue(batchSize, bindingArray.data(), stream.get(), nullptr);
assert(success);
enum class SyncType {
Stream,
Event
std::thread repeatWithSync(SyncType syncType, std::function<void(Task&)> threadInit = nullptr);
static void signalHandler(int s) {
gStop = true;
static bool shouldStop() {
return gStop;
// called from master thread when repeatWithSync is running
float reportFPS() {
const size_t frames = counter->load();
counter->fetch_sub(frames); //reset counter safely
auto timeEnd = std::chrono::steady_clock::now();
const float fps = frames / std::chrono::duration_cast<std::chrono::duration<float>>(timeEnd - timeBeg).count();
timeBeg = timeEnd;
return fps;
private:
static Logger gLogger;
static std::atomic_bool gStop;
UniqPtr<IRuntime> runtime = UniqPtr<IRuntime>{ createInferRuntime(gLogger) };
std::unique_ptr<std::atomic_size_t> counter = std::unique_ptr<std::atomic_size_t>(new std::atomic_size_t(0));
UniqPtr<ICudaEngine> engine = nullptr;
UniqPtr<IExecutionContext> context = nullptr;
std::vector<UniqPtr<char, CuMemDeleter>> bindings;
std::vector<void*> bindingArray;//same content as bindings
std::unique_ptr<CUstream_st, StreamDeleter> stream;
std::unique_ptr<CUevent_st, EventDeleter> event;
//for use by host thread
std::chrono::time_point<std::chrono::steady_clock> timeBeg;
Logger Task::gLogger;
std::atomic_bool Task::gStop;
Task::Task(const char* filename, int dlaCore, int streamCreateFlag, int eventCreateFlag)
: stream{makeCudaStream(streamCreateFlag)}
, event{makeCudaEvent(eventCreateFlag)}
if (dlaCore >= 0)
runtime->setDLACore(dlaCore);
std::cout << "Load engine from :" << filename << std::endl;
std::ifstream fin(filename, std::ios::binary);
std::vector<char> inBuffer((std::istreambuf_iterator<char>(fin)), std::istreambuf_iterator<char>());
engine.reset(runtime->deserializeCudaEngine(inBuffer.data(), inBuffer.size(), nullptr));
assert(engine);
context.reset(engine->createExecutionContext());
const int nbBindings = engine->getNbBindings();
for (int i = 0; i < nbBindings; i++) {
const auto dataType = engine->getBindingDataType(i);
const int elemSize = [&]() -> int {
switch (dataType) {
case DataType::kFLOAT: return 4;
case DataType::kHALF: return 2;
default: throw std::runtime_error("invalid data type");
const auto dims = engine->getBindingDimensions(i);
const int bindingSize = elemSize * std::accumulate(dims.d, &dims.d[dims.nbDims], 1, std::multiplies<int>{});
bindings.emplace_back(mallocCudaMem<char>(bindingSize));
bindingArray.emplace_back(bindings.back().get());
std::thread Task::repeatWithSync(Task::SyncType syncType, std::function<void(Task&)> threadInit) {
return std::thread([this, syncType, threadInit]() {
if (threadInit)
threadInit(*this);
counter->store(0);
timeBeg = std::chrono::steady_clock::now();
while(!gStop){
exec_once();
switch (syncType) {
case SyncType::Stream: checkCudaErrors(cudaStreamSynchronize(stream.get())); break;
case SyncType::Event:
checkCudaErrors(cudaEventRecord(event.get(), stream.get()));
checkCudaErrors(cudaEventSynchronize(event.get()));
break;
default: throw std::runtime_error("invalid sync type");
counter->fetch_add(1);
int main(int argc, char* argv[])
// Configurations
const int streamCreateFlags = cudaStreamDefault;
const int eventCreateFlags = cudaEventBlockingSync;
auto threadInit = [](Task& task)->void {
// If you want to do something at the begining of each worker threads, put it here.
const Task::SyncType syncType = Task::SyncType::Event;
// Configuration is done. Now we start.
signal(SIGINT, Task::signalHandler);
std::vector<Task> tasks;
for (int i = 0; i < argc-1; i++) {
const int dlaCore = std::stoi(argv[i + 1]);
const char* filename = dlaCore < 0 ? "gpu.engine" : "dla.engine";
tasks.emplace_back(filename, dlaCore, streamCreateFlags, eventCreateFlags);
std::vector<std::thread> workers;
for (Task& task : tasks)
workers.emplace_back(task.repeatWithSync(syncType, threadInit));
while (!Task::shouldStop()) {
std::this_thread::sleep_for(std::chrono::seconds(1));
std::cout << "FPS:\t";
for (auto& task : tasks)
std::cout << task.reportFPS() << "\t";
std::cout << std::endl;
for (auto& thrd : workers)
thrd.join();
workers.clear();
return 0;
