• Hardware Platform (Jetson / GPU) 1080Ti, RTX 3060 • DeepStream Version 6.0.0 • JetPack Version (valid for Jetson only) • TensorRT Version 8.2.0.6 • NVIDIA GPU Driver Version (valid for GPU only) 470.82.01 • Issue Type( questions, new requirements, bugs) questions • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Hello everyone!
I want to do inference in deepstream from specific engine like primary engine without reloading it another time - because loading it consume GPU Memory again . Currently, I reload it but it approximately consumes 1GB of GPU Memory. Is there a way to do that?
I hope I could explain it. I know it’s somewhat a special case. I want to do inference myself not via pipeline. When primary engine set up in pipeline I just read metadata outputs from input streams and I could not feed desired image to this engine and then parse metadata from it. I’d like to feed out of pipeline, also.
Assume that you have a car detection model. The pgie generates a metadata and this metadata contains a mat (in dsexample) . Now I want to do pgie another time for this mat . I want to avoid loading trt engine twice.
