How to do inference with fpenet_fp32.trt
I am using TLT v3 and fetched the fpenet model using
ngc registry model download-version nvidia/tlt_fpenet:trainable_v1.0
Then, I converted the fpenet.tlt model to model.etlt using fpenet export. After that, using the tlt-convert tool, I created a .trt file in order to use that in a Python application.
Here is the tlt-convert command I used:
tlt-converter fpenet.etlt -k nvidia_tlt -p input_face_images:0,1x1x80x80,1x1x80x80,1x1x80x80 -b 1 -t fp32 -e fpenet_b1_fp32.trt
The problem I am facing is that the inference output is not what it is supposed to be; i.e., when compared with the output of fpenet inference, it is not even close. I suspect that either the conversion step is causing the issue, or my preprocessing is not what it should be.
Here is the inference code I am using:
test.py (4.8 KB)
and I run it with this command: python3 test.py --input p.jpg
p2
The output is this:
landmarks
However, the output that the fpenet inference command creates by following fpenet.ipynb is this:
You can clearly see that the first output is not sensible at all.
Could you please help me find the problem in the process?
Thanks for your help.
For fpenet in TLT, by default, there are only two ways for inference. Facial Landmarks Estimation — Transfer Learning Toolkit 3.0 documentation and Facial Landmarks Estimation — Transfer Learning Toolkit 3.0 documentation
I already have read the fpenet documentation from the TLT 3.0 documentation. However, what I need is to infer in Python code. fpenet inference or TLT CV inference Pipeline do not fit my requirements as I need to perform face alignment using the facial landmarks in a real-time face recognition pipeline that is built in Python. Note that I created the .trt engine file from your previous answer.
My problem is that the inference output from the engine file significantly differs from the model.tlt output and is not accurate. I appreciate it if you could help me solve this or find out what the problem is.
Please crop the face bounding box to be a square bbox. Then run your code to do inference against this square bbox. It will get the same result as fpenet inference.
I tried my code with a square input image, but the result is not the same as the fpenet inference output.
Here is the output I get after feeding a 400x400 image to my code:
landmarks
I also tried a couple of slightly different bounding boxes with different sizes, but the output is not desirable.
Could you please share an input image and/or possible edits you applied to my code?
test
Run following command against above png file.
or test_1
This is the output of running test.py --input test.png. Still, it is not satisfactory.
landmarks
Do you have any idea about it?
On my side, it works well.
landmarks
My step:
# tlt-converter pretrained_models/public/model.etlt -k nvidia_tlt -p input_face_images:0,1x1x80x80,1x1x80x80,1x1x80x80 -b 1 -t fp32 -e fpenet_b1_fp32.trt
[WARNING] onnx2trt_utils.cpp:220: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[INFO] Detected input dimensions from the model: (-1, 1, 80, 80)
[INFO] Model has dynamic shape. Setting up optimization profiles.
[INFO] Using optimization profile min shape: (1, 1, 80, 80) for input: input_face_images:0
[INFO] Using optimization profile opt shape: (1, 1, 80, 80) for input: input_face_images:0
[INFO] Using optimization profile max shape: (1, 1, 80, 80) for input: input_face_images:0
[INFO] Detected 1 inputs and 2 output network tensors.
Modify your code to
fpenet_obj = FpeNet(‘fpenet_b1_fp32.trt’)
I try to do same as Aref, but also got unsatisfied result, here are the config ,steps ans result. I used your recommended resized picture as input
| NVIDIA-SMI 418.67 Driver Version: 418.67 CUDA Version: 11.1 |
| 0 Tesla T4 Off | 00000000:21:01.0 Off | 0 |
| N/A 52C P0 28W / 70W | 5457MiB / 15079MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
tlt-converter tlt_fpenet_vdeployable_v1.0/model.etlt -k nvidia_tlt -p input_face_images:0,1x1x80x80,1x1x80x80,1x1x80x80 -b 1 -t fp32 -e fpenet_b1_fp32.trt
landmarks
landmarks
Please retry with below modification.
img_np = img_np.astype(np.float32) / 255
to
This solved the issue. Thanks!
Did you use this on jetson NX? or PC? What is the approximate fps of the 68-point facial landmarks? Is it faster than Dlib model? thanks!
Hi @154221990 ,
I used this on an x86 PC with an Nvidia GTX 1080 Ti. The approximate framerate is about 1500fps. Yes, it is much faster than the dlib model. I got about 1000fps on my CPU using the dlib’s 5-points landmark detector. I did not test the dlib’s 68-points landmark detector tough.
Also, refer to NVIDIA NGC for more info and the official benchmarks.
many thanks for your reply.
