How to Do segmentation with the help of Clara? And any documents on how to use clara?
Please take a look at the information in the link below
and apply for early access to the Clara SDK. It comes with easy to follow examples.
Clara allows you to quickly stand up inferencing for your tasks (e.g. segmentation), however, it does not perform segmentaiton out of the box. You have to have a trained model that performs semgnentation.
If you want to use a pre-trained model please check the Transfer Learning Toolkit https://developer.nvidia.com/transfer-learning-toolkit and apply for early access. TLT will allow you to pull a pre-trained model and refine its accuracy on your own data.
