Hello, we have a test with a CS7510 which requires legacy MLNX_OS 3.6.5009. How to download this version ?
Hi ,
This version is too old, which has been end of service.
Why you need this version?
Thanks,
Suo
Hi Suo,
We have an entire infrastructure with outdated versions, with one faulty switch to be replaced. We need to downgrade tne the replacement switch to this old version for end-to-end consistency across the IB fabric.
Envoyé à partir de Outlook pour Android
Could you check if you have this version in other switch?
You can login to another switch use command show images .
Then it will list all available images.
And if you have this version, you can sftp to the switch. go to foder. /var/opt/tms/images. to download it.
Thanks,
Suo
I’ll check this with our technical team next week.
Thanks for the advice.
